KnowIT
Oct 12, 2010Aspirant
GSM7224 VLAN and trunking with Cisco
Hi, We've just bought a GSM7224v2 and we're trying to get it work with our Cisco 2960 but to no avail. The Cisco has 3 VLAN configured and we would like to be able to use these VLANs on the GSM...
spuluka
Oct 17, 2010Tutor
The assignment of ports to vlans is under the switching menu. This is the Netgear to Cisco "translation" terminology.
Untagged = Access
Tagged = Trunk port 802.1q
Create your vlans under the basic menu
On the advanced menu -- vlan membership
Select vlan 1 (the default vlan) and remove all the ports you want to use for the other vlans you created. But in your case it sounds like one of the three vlans is the Cisco native vlan so you can leave this default vlan 1 here and pass it over untagged on the trunk port.
On the trunk port add in as a "tagged" vlan the other two you want to trunk.
