KnowIT
Oct 12, 2010Aspirant
GSM7224 VLAN and trunking with Cisco
Hi, We've just bought a GSM7224v2 and we're trying to get it work with our Cisco 2960 but to no avail. The Cisco has 3 VLAN configured and we would like to be able to use these VLANs on the GSM...
RKnebel
Apr 24, 2014Tutor
dwchan69,
With the trunk port, you will want to set VLANs 10, 20, and 200 as tagged.
I would then set VLAN 1 as untagged on the Netgear, and set the PVID as VLAN 1 for the trunk port. This is like setting "switchport trunk native vlan 1" on a Cisco switch. It means that everything that you haven't specifically tagged will be sent on VLAN 1, and therefore not used.
