EA1DDO
Mar 14, 2013Aspirant
GSM7224R small network
Hi all, I just bought an GSM7224R switch to create a small network in a building. The idea is to isolate different areas from eachother; customer free wifi, own home, CCTV IP Cameras/NVR system, ...
jmizoguchi
Mar 14, 2013Virtuoso
You will be better to use VLAN capable router with Layer2 switch that can also do clan
Your ZTE ZXV10W300 is DSL /wireless gateway. If you are using PPPoE, I would put ZTE in bridge mode (consult ISP) and use router like Prosafe FVS318N.
http://www.netgear.com/business/products/security/wireless-vpn-firewalls/fvs318n.aspx
