EA1DDO
Mar 14, 2013Aspirant
GSM7224R small network
Hi all, I just bought an GSM7224R switch to create a small network in a building. The idea is to isolate different areas from eachother; customer free wifi, own home, CCTV IP Cameras/NVR system, ...
EA1DDO
Mar 15, 2013Aspirant
Hi,
The ZTE ZXV10W300 is VLAN capable;
ZTE ZXV10W300 Manual
Should I configure the VLAN in both router and switch?
I guess it will need to match side to side and use tagged link, isn“t it?
Do you know any document or example I can have a look?
Thank you
Regards, Maximo
jmizoguchi wrote: You will be better to use VLAN capable router with Layer2 switch that can also do clan
Thank you
Regards, Maximo
