EA1DDO
Mar 14, 2013Aspirant
GSM7224R small network
Hi all, I just bought an GSM7224R switch to create a small network in a building. The idea is to isolate different areas from eachother; customer free wifi, own home, CCTV IP Cameras/NVR system, ...
EA1DDO
Mar 19, 2013Aspirant
Hi all,
I have successfully created a second vlan, exactly vlan2, pvid2.
There are six ports assigned to this vlan2. Rest of the ports are still default, in vlan1 (192.168.1.100)
I could enable the DHCP and DHCP pool (192.168.10.x) to this vlan2 and now when you connect to anyone from those six ports, you get an IP from that subnet.
At the same time, I have created a "DefaultRoute" if the router gateway IP 192.168.1.1
This is how it looks;
The only problem is that from vlan2 I can not reach the router gateway, it seems that "DefaultRoute" is not working.
Any idea?
Thank you
Regards, Maximo.
Any idea?
Thank you
Regards, Maximo.
