EA1DDO
Mar 14, 2013Aspirant
GSM7224R small network
Hi all, I just bought an GSM7224R switch to create a small network in a building. The idea is to isolate different areas from eachother; customer free wifi, own home, CCTV IP Cameras/NVR system, ...
jmizoguchi
Mar 19, 2013Virtuoso
you need to able to forward the port 8200 on main router
you need match the Vlan ID on main router too
The only problem is that from vlan2 I can not reach the router gateway, it seems that "DefaultRoute" is not working.
