EA1DDO
Mar 14, 2013Aspirant
GSM7224R small network
Hi all, I just bought an GSM7224R switch to create a small network in a building. The idea is to isolate different areas from eachother; customer free wifi, own home, CCTV IP Cameras/NVR system, ...
EA1DDO
Mar 20, 2013Aspirant
Hi all,
Finally I have founded that thread;
http://forum1.netgear.com/showthread.php?t=27956
How should those static routes look ?
I meant, What IPs to use?
Thank you
i would simply create a 3rd vlan using the wizard and assign only 1 port and an ip-address from 192.168.0.x to it. connect your router to that port then
all you need to do then is put static routes for each vlan into the router.
Thank you
