lutz
Jul 19, 2011Aspirant
GSM7328Sv2 - 245 degrees Celsius ?
I wonder about following syslog entries from a GSM7328Sv2 Netgear Switch:
I then loggend into the switch and did a show hardware:
What does this mean ? Is this another bug in the Netgear Firmware ?
UNITMGR[213901824]: hpc_local_sensors.c(524) 395000 %% CPU Maximum Temperature Exceeded (245 degrees Celsius).
UNITMGR[213901824]: hpc_local_sensors.c(524) 398486 %% CPU Maximum Temperature Exceeded (245 degrees Celsius).
Temperature:
Unit Description Value
1 CPU 50c
1 System 42c
1 MAC 54c
1 Reply
- GlitchedAspirantI tested this on firmware 8.0.3.15 and was not able to reproduce the issue. If you're not on this firmware you can download it here
If you do have the latest firmware please tell me what severity filter you tried, I tried all of them, but I didn't wait to long before changing between them(5 minutes or so).
