rmolinari69
Feb 21, 2017Aspirant
GSM7328Sv2 Stack member Status is not present
Hi, I'm new in nthis community. My problem is this. I have 2 GSM7328Sv2 switch stacking mode. Id Unit 1 is in the management status and unit id 2 is in stackmember status. In recent days the ...
DanielZhang
Feb 21, 2017NETGEAR Expert
Hi Rmolinari69,
Welcome to NETGEAR community! :smileyhappy:
Could you please follow belows checkpoint to diagnosis:
- Which version running on GSM7328Sv2?
- Which fiber module link between Unit 1 and Unit 2?
- Does the fiber module link up now?
- Please collect the stack information from command line interface as below:(you can login switch through telnet and input belows commands)
show switch
show stack-port
show stack-port diag
show stack-port counters
show eventlog
Please send the echo message from switch to us after you input above commands.
You can also send me a private message about echo message If any privacy you want to keep. :smileyhappy:
- rmolinari69Feb 21, 2017Aspirant
Hi Daniel,
1. my version running on GSM7328Sv2 IS v1
2. The fiber module link between unit 1 and 2 is AX742
3. The front panel leds on the stack master switch (unit id 1) show a green light on Power, Fan, RPS, Stacl Master M1 and M2 Led
The front panel leds on the stack member switch (unit id 2) show a green light on Power, Fan and M1 Led (not M2 Led)
4. This are the output of your telnet command line:
(GSM7328Sv2) >show switch
Management Standby Preconfig Plugged-in Switch Code
SW Switch Status Model ID Model ID Status Version
1 Stack Mbr Oper Stby GSM7328Sv2 GSM7328Sv2 OK 8.0.0.25
2 Mgmt Sw GSM7328Sv2 GSM7328Sv2 OK 8.0.0.25(GSM7328Sv2) >show stack-port
% Invalid input detected at '^' marker.(GSM7328Sv2) >show stack-port diag
% Invalid input detected at '^' marker.(GSM7328Sv2) >show eventlog
% Invalid input detected at '^' marker.******************************************************************************************************
Thank you.
- DanielZhangFeb 21, 2017NETGEAR Expert
Hi Rmolinari69,
Please enter the "enable" mode before you input these commands.
Such as:
1.Login DUT.
2.Input Username and password.
3.input enable and then enter
such as:
User:admin
Password:
(GSM7328Sv2) >enable
(GSM7328Sv2) #show port all- rmolinari69Feb 21, 2017Aspirant
Hi Daniel,
thank you for your help.
This is the output of the telnet command:
(GSM7328Sv2) #show switch
1 Mgmt Sw GSM7328Sv2 GSM7328Sv2 OK 8.0.0.25
2 Stack Mbr Oper Stby GSM7328Sv2 GSM7328Sv2 OK 8.0.0.25(GSM7328Sv2) #show stack-port
Configured Running Link
Stack Stack Link Speed
Unit Intf SlotId Type XFP Adapter Mode Mode Status (Gb/s)
1 0/27 AX742 (stack) Stack Stack Link Up 12
1 0/28 None Stack Stack Link Down 0
2 0/27 None Stack Stack Link Down 0
2 0/28 AX742 (stack) Stack Stack Link Up 12(GSM7328Sv2) #show stack-port diag
1 - 0/27:
RBYT:3199663109 RPKT:108512816 TBYT:410327130 TPKT:643627015
RFCS:1 RFRG:0 RJBR:0 RUND:0 ROVR:7220482
TFCS:0 TERR:01 - 0/28:
RBYT:0 RPKT:0 TBYT:0 TPKT:0
RFCS:0 RFRG:0 RJBR:0 RUND:0 ROVR:0
TFCS:0 TERR:02 - 0/27:
TFCS:0 TERR:02 - 0/28:
RBYT:914096216 RPKT:632797731 TBYT:1355995402 TPKT:83854182
RFCS:0 RFRG:0 RJBR:0 RUND:0 ROVR:611679070
TFCS:0 TERR:0
(GSM7328Sv2) #show stack-port counters------------TX-------------- ------------RX--------------
Data Error Data Error
Rate Rate Total Rate Rate Total
Unit Interface (Mb/s) (Errors/s) Errors (Mb/s) (Errors/s) Errors
1 0/27 0 0 0 0 0 1
1 0/28 0 0 0 0 0 0
2 0/27 0 0 0 0 0 0
2 0/28 0 0 0 0 0 0(GSM7328Sv2) #show eventlog
Time
File Line TaskID Code d h m s
EVENT> bootos.c 227 0FFFFD20 AAAAAAAA 0 0 0 7
EVENT> bootos.c 227 0FFFFD20 AAAAAAAA 0 0 0 8
EVENT> unitmgr.c 5032 0615FE10 00000000 1 20 0 27
EVENT> unitmgr.c 5032 061994E0 00000000 0 0 4 18EVENT> bootos.c 227 0FFFFD20 AAAAAAAA 0 0 0 7
EVENT> unitmgr.c 5032 0631B010 00000000 0 3 17 38
EVENT> unitmgr.c 5032 061BB1B0 00000000 0 0 1 39
EVENT> unitmgr.c 5032 0631AE90 00000000 0 0 0 42
EVENT> unitmgr.c 5032 061A3960 00000000 0 0 0 59
EVENT> unitmgr.c 5032 061826C0 00000000 0 0 1 2
EVENT> bootos.c 227 0FFFFD20 AAAAAAAA 0 0 0 6
EVENT> unitmgr.c 5032 0631B520 00000000 0 0 0 47
EVENT> bootos.c 227 0FFFFD20 AAAAAAAA 0 0 0 9EVENT> bootos.c 227 0FFFFD20 AAAAAAAA 0 0 0 8
Riccardo.
