rmolinari69
Feb 21, 2017Aspirant
GSM7328Sv2 Stack member Status is not present
Hi, I'm new in nthis community. My problem is this. I have 2 GSM7328Sv2 switch stacking mode. Id Unit 1 is in the management status and unit id 2 is in stackmember status. In recent days the ...
rmolinari69
Hi Daniel,
1. my version running on GSM7328Sv2 IS v1
2. The fiber module link between unit 1 and 2 is AX742
3. The front panel leds on the stack master switch (unit id 1) show a green light on Power, Fan, RPS, Stacl Master M1 and M2 Led
The front panel leds on the stack member switch (unit id 2) show a green light on Power, Fan and M1 Led (not M2 Led)
4. This are the output of your telnet command line:
(GSM7328Sv2) >show switch
Management Standby Preconfig Plugged-in Switch Code
SW Switch Status Model ID Model ID Status Version
1 Stack Mbr Oper Stby GSM7328Sv2 GSM7328Sv2 OK 8.0.0.25
2 Mgmt Sw GSM7328Sv2 GSM7328Sv2 OK 8.0.0.25
(GSM7328Sv2) >show stack-port
% Invalid input detected at '^' marker.
(GSM7328Sv2) >show stack-port diag
(GSM7328Sv2) >show eventlog
Thank you.
DanielZhang
Feb 21, 2017NETGEAR Expert
Hi Rmolinari69,
Please enter the "enable" mode before you input these commands.
Such as:
1.Login DUT.
2.Input Username and password.
3.input enable and then enter
such as:
User:admin
Password:
(GSM7328Sv2) >enable
(GSM7328Sv2) #show port all
- rmolinari69Feb 21, 2017Aspirant
Hi Daniel,
thank you for your help.
This is the output of the telnet command:
(GSM7328Sv2) #show switch
1 Mgmt Sw GSM7328Sv2 GSM7328Sv2 OK 8.0.0.25
2 Stack Mbr Oper Stby GSM7328Sv2 GSM7328Sv2 OK 8.0.0.25(GSM7328Sv2) #show stack-port
Configured Running Link
Stack Stack Link Speed
Unit Intf SlotId Type XFP Adapter Mode Mode Status (Gb/s)
1 0/27 AX742 (stack) Stack Stack Link Up 12
1 0/28 None Stack Stack Link Down 0
2 0/27 None Stack Stack Link Down 0
2 0/28 AX742 (stack) Stack Stack Link Up 12(GSM7328Sv2) #show stack-port diag
1 - 0/27:
RBYT:3199663109 RPKT:108512816 TBYT:410327130 TPKT:643627015
RFCS:1 RFRG:0 RJBR:0 RUND:0 ROVR:7220482
TFCS:0 TERR:01 - 0/28:
RBYT:0 RPKT:0 TBYT:0 TPKT:0
RFCS:0 RFRG:0 RJBR:0 RUND:0 ROVR:0
TFCS:0 TERR:02 - 0/27:
TFCS:0 TERR:02 - 0/28:
RBYT:914096216 RPKT:632797731 TBYT:1355995402 TPKT:83854182
RFCS:0 RFRG:0 RJBR:0 RUND:0 ROVR:611679070
TFCS:0 TERR:0
(GSM7328Sv2) #show stack-port counters------------TX-------------- ------------RX--------------
Data Error Data Error
Rate Rate Total Rate Rate Total
Unit Interface (Mb/s) (Errors/s) Errors (Mb/s) (Errors/s) Errors
1 0/27 0 0 0 0 0 1
1 0/28 0 0 0 0 0 0
2 0/27 0 0 0 0 0 0
2 0/28 0 0 0 0 0 0(GSM7328Sv2) #show eventlog
Time
File Line TaskID Code d h m s
EVENT> bootos.c 227 0FFFFD20 AAAAAAAA 0 0 0 7
EVENT> bootos.c 227 0FFFFD20 AAAAAAAA 0 0 0 8
EVENT> unitmgr.c 5032 0615FE10 00000000 1 20 0 27
EVENT> unitmgr.c 5032 061994E0 00000000 0 0 4 18EVENT> bootos.c 227 0FFFFD20 AAAAAAAA 0 0 0 7
EVENT> unitmgr.c 5032 0631B010 00000000 0 3 17 38
EVENT> unitmgr.c 5032 061BB1B0 00000000 0 0 1 39
EVENT> unitmgr.c 5032 0631AE90 00000000 0 0 0 42
EVENT> unitmgr.c 5032 061A3960 00000000 0 0 0 59
EVENT> unitmgr.c 5032 061826C0 00000000 0 0 1 2
EVENT> bootos.c 227 0FFFFD20 AAAAAAAA 0 0 0 6
EVENT> unitmgr.c 5032 0631B520 00000000 0 0 0 47
EVENT> bootos.c 227 0FFFFD20 AAAAAAAA 0 0 0 9EVENT> bootos.c 227 0FFFFD20 AAAAAAAA 0 0 0 8
Riccardo. - rmolinari69Feb 22, 2017Aspirant
Hello Daniel,
the firmware version of my switch is very old.
Advise me to do a firmware update or before I have to understand the cause of the problem?
The latest version of the firmware that I found on the internet is as follows:
What do you recommend me ?
Thank you.
Hi Daniel,
this morning in the Monitoring->Logs->Buffered Logs i show more of this messages:
<10> FEB 23 06:11:51 172.22.247.31-2 UNKN[135175984]: hpc_local_sensors.c(229) 3617 %% (null):32776032: Temp sensor 229 i2c operation failed
<14> FEB 23 06:12:38 172.22.247.31-1 UNKN[102006400]: isdp_txrx.c(154) 3623 %% Foreign pdu on interface 13
<13> FEB 23 06:13:35 172.22.247.31-1 TRAPMGR[213470768]: traputil.c(615) 3628 %% Temperature change alarm: Sensor ID: 0 Event: 2
<14> FEB 23 06:13:38 172.22.247.31-1 UNKN[102006400]: isdp_txrx.c(154) 3629 %% Foreign pdu on interface 13
<13> FEB 23 06:13:40 172.22.247.31-1 TRAPMGR[213470768]: traputil.c(615) 3630 %% Temperature change alarm: Sensor ID: 0 Event: 1<14> FEB 23 06:14:39 172.22.247.31-1 UNKN[102006400]: isdp_txrx.c(154) 3631 %% Foreign pdu on interface 13
<14> FEB 23 06:31:38 172.22.247.31-1 UNKN[102006400]: isdp_txrx.c(154) 3724 %% Foreign pdu on interface 13
<13> FEB 23 06:32:34 172.22.247.31-1 TRAPMGR[213470768]: traputil.c(615) 3725 %% Temperature change alarm: Sensor ID: 0 Event: 2
<14> FEB 23 06:32:38 172.22.247.31-1 UNKN[102006400]: isdp_txrx.c(154) 3726 %% Foreign pdu on interface 13
<13> FEB 23 06:32:39 172.22.247.31-1 TRAPMGR[213470768]: traputil.c(615) 3727 %% Temperature change alarm: Sensor ID: 0 Event: 1Now my unit id 1 is the management switch and unit id 2 is the stackmember.
Last night the unit id 2 is crashed.
Latest posts you gave me were the following:
<10> FEB 22 18:55:26 172.22.247.31-1 UNKN[213470768]: hpc_local_sensors.c(229) 423 %% (null):32776032: Temp sensor 229 i2c operation failed
<10> FEB 22 18:55:31 172.22.247.31-1 UNKN[213470768]: hpc_local_sensors.c(229) 424 %% (null):32776032: Temp sensor 229 i2c operation failed
<13> FEB 22 18:55:32 172.22.247.31-1 TRAPMGR[213470768]: traputil.c(615) 425 %% Temperature change alarm: Sensor ID: 0 Event: 1
<14> FEB 22 18:55:38 172.22.247.31-1 UNKN[102006400]: isdp_txrx.c(154) 426 %% Foreign pdu on interface 13
<10> FEB 22 18:56:22 172.22.247.31-2 UNKN[135175984]: hpc_local_sensors.c(229) 427 %% (null):32776032: Temp sensor 229 i2c operation failed
<14> FEB 22 18:56:38 172.22.247.31-1 UNKN[102006400]: isdp_txrx.c(154) 428 %% Foreign pdu on interface 13
<10> FEB 22 18:57:00 172.22.247.31-1 UNKN[213470768]: hpc_local_sensors.c(229) 429 %% (null):32776032: Temp sensor 229 i2c operation failedI could try to stop the switch and clean them from dust?
The problem may becaused by a faulty fan?
How can I check the status of the fans by the management console ?
Thanks.
- DanielZhangFeb 22, 2017NETGEAR Expert
Hi Rmolinari,
Sorry for the delay of response.
1. According the information of your reply.
The stack-link work correctly between Unit 1 and Unit 2 of GSM7328Sv2.
It seems that a hardware issue of GSM7328Sv2 appeared on Unit2.
Please contact NETGEAR support about it.
2. You can input "show environment" to check fan and temperature information.(Login switch and input "enable" before show commands
3. I don't suggest you upgrade the switch because it maybe a hardware issue.
But if you want to try it .
The best way to upgrade is from 8.0.3.x first and check if stack work correctly.
Then upgrade to 10.0.0.x from 8.0.3.25 if error occur all the same.
Please use the TFTP to upgrade and reference below example of community.
Please get the firmware from NETGEAR website :
http://www.netgear.com/support/product/gsm7328sv2.aspx#download
May the solution help you. :smileyhappy:
- rmolinari69Feb 23, 2017Aspirant
Hi Daniel,
I power off the switch member (the bad switch) and than I uninstall the link module AX742 and than I installed it in the third switch(the goog switch). I disconnected the ethernet cables from the bad switches, and I reconnected them in the good switch in the same position ports (before I had configured it by copying the configuration from the master switch). I connected the two modules AX742 (of the master and the good switch) and than power-on the good switch.
After power-on the switch, the master switch show the good switch as stackmember, switch type GSM7328Sv2 (the same type of the master), the version of firmware 8.0.3.15 (the master firmware is 8.0.0.25), but it show me the status switches as "configuration mismatch" .
The good switch ports had not seen by the master and none of them blinking.
Than I preferred to return to the initial situation.
Have you any suggestions on the cause of the status "configuration mismatch"?
The good switch I had pre-confgurato(copy the configuration by the master) before I connect it to the master switch.
Must I reset the good switch configuration and try again?Thanks you.
