rmolinari69
Feb 21, 2017Aspirant
GSM7328Sv2 Stack member Status is not present
Hi, I'm new in nthis community. My problem is this. I have 2 GSM7328Sv2 switch stacking mode. Id Unit 1 is in the management status and unit id 2 is in stackmember status. In recent days the ...
DanielZhang
Feb 23, 2017NETGEAR Expert
Hi Rmolinari,
Did it mean that you want to separate the Unit 2 from the stack?
Then put it to maintenance about clean dust or RMA?
It will make these two GSM7328Sv2 switch work as standalone mode after disconnect stack link.
I suggest you to backup configuration for stack before next operation.
You can remove the cable on AX742 between two unit then wait for a minute.
The stack will separate to two standalone GSM7328Sv2 .
It's no need to remove AX742 module of GSM7328Sv2.
Clean the dust may do some help for unit 2 just as you said.
rmolinari69
Feb 23, 2017Aspirant
Hello Daniel,
I found a third GSM7328S (serial: 1J867C5D00132) switch with the firmware version 8.0.3.15.
How I do replace this switch with the unit id 2 switch in staching configuration ?
When I disconnect the link cable that ip address take 2 switches(management and stackmember)?.
After disconnecting the cable link I can bring the configuration of the second swtich on the third switch, install the AX742 module on the new switch and reconnect the link cable ?
Thanks.
