audleytravel
Feb 15, 2011Aspirant
GSM7352Sv1 Netapp LACP LAG
Hey, Trying to configure an LACP LAG with a GSM7352S and our Netapp FAS2020 SAN but I can only ever get one port to come up. We have an 8 switch stack (GSM7352S). We're using 2/0/14 and 2/0/16 ...
advantagecom
Feb 15, 2011Novice
Did you plug in the cables and then configure the LAG or did you configure the LAG and then plug in the cables? The order matters. Spanning tree may have disabled a port if you plugged in the cables before configuring the LAG. I know you said you disabled spanning tree, but I'm presuming that was done as part of the LAG configuration, so spanning tree may have been on when the cables were plugged in if the cables were plugged in first.
Another possibility is that the port in question is actually admin'ed down. Have you checked that?
Try different ports on the switch.
