audleytravel
Feb 15, 2011Aspirant
GSM7352Sv1 Netapp LACP LAG
Hey, Trying to configure an LACP LAG with a GSM7352S and our Netapp FAS2020 SAN but I can only ever get one port to come up. We have an 8 switch stack (GSM7352S). We're using 2/0/14 and 2/0/16 ...
audleytravel
Figured it out after looking at a similar post where the solution was that the SAN engineer had split the 2 controllers over 2 switches which inspired me to try both LAG members on the same switch and *Bish*Bosh*Wallup* Up they came!!!
Looks like Netapp/Netgear don't like to play nice when using cross-stack LAG. I'm sure the GSM7352S supports cross stack LACP because it allows you to configure it both in the web console and line console. Could it be that there's a config that will allow me to cross-stack LACP LAG?
Thanks again,
Pat
Thanks again,
Pat
