audleytravel
Feb 15, 2011Aspirant
GSM7352Sv1 Netapp LACP LAG
Hey, Trying to configure an LACP LAG with a GSM7352S and our Netapp FAS2020 SAN but I can only ever get one port to come up. We have an 8 switch stack (GSM7352S). We're using 2/0/14 and 2/0/16 ...
audleytravel
Feb 16, 2011Aspirant
We're using 8 GSM7352S v1's using the 24Gbps stacking modules.
What are you LAG'ing? I haven't tested it but I'm assuming cross stack LAGs between switches will work but have you tried it with a Netapp FAS2020 SAN?
I figured it was a difference in the way Netapp and Netgear chose to implement LACP but it could just be a configuration that I've missed. I'll be vlan'ing and subnetting before I turn on jumbo frames so when I've done all that, I'll come back to the cross stack LAG issue.
Chances are, we will be buying a couple of Cisco 3750-48T's for our storage/server network which I'm certain will do cross stack LAG with the Fas2020 but if you think I can do the same with a couple of GSM7352S's, I can save about £9000!!!
Thanks again,
Pat
Thanks again,
Pat
