fr4nk18
Sep 17, 2018Aspirant
Help M7100 MLAG is driving me mad
Morning everyone .. i am looking to get some form of help from the community about a frustrating sets of problems we are having with MLAG and 4 M7100s switches .I would hopefully receive back a runni...
DaneA
Oct 03, 2018NETGEAR Employee Retired
Hi fr4nk18,
Welcome to the community! :)
I inquired your concern to the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, the configuration you have posted is correct. Let me share the article below:
MLAG on M7100--Basic setup and best practice
Please note what is says about Redundancy from the article above: “When connecting equipment to MLAG switches, this connection should be done redundantly. Ideally, non-redundant equipment is connected through a redundantly-connected edge or core switch.”
what we would like to achieve is having a connection between hosts connected in the 10G switch stack with hosts connected in 1G switch (in the same private B class) with or without routing ....
On SW1 and SW2, you can only connect devices by using LAGs. Therefore, a PC with a single NIC card that is connected to either SW1 or SW2, will not be able to communicate with Lab Switch.
Kindly answer the questiions below:
a. On SW1 and SW2 connectivity needs to be achieved by the use of LAGs. Therefore, if you connect a host without configuring a LAG, the host will not be able to connect to Lab Switch. Are LAGs used for every device connected to SW1 or SW2?
b. The expected behavior is that on SW3 and SW4, no LAGs are needed to be configured on the connected devices in order for them to be able to have full connectivity with the Lab Switch. Can you confirm that this is the actual behavior?
DaneA
NETGEAR Community Team
fr4nk18
Oct 09, 2018Aspirant
Hi DaneA
Sorry for my delayed answer i was off for a few days (to recover after the fight with the Netgear switches
Coming to your questions and notes ...
I read the articles so many times i can repeat it while on waterboarding
) however it did not help .The best should be to have a complete running config .I requested support and i received it .. actually i did not have the time to test it but will do and share the results
a: I configured a server with two netowrk cards in a bonding configuration with a leg in sw1 and a leg on sw2 ... The result was not as planned (communicating with the lab switch)
b: i tried as well to connect a single network card host on sw3 with the same depressing results as above
As per your understanding an host connected to the lab switch could be single carded isn't it ?
The same for sw3 and sw4 while on sw1-2 the connection has to be made on each side in bonding ( wondering if the bonding type can make a difference)
Then what happened was a complete debacle except some success pinging the lab switch from a correctly connected double carded host on sw1-2 but was not possible to ping an host connected to the lab switch in single connection ...
this is what i have to share right now .. hopefully this week beginning of the next i would try the configuration Netgear support gave me
thanks for support and feel free to ask
Francesco
