captainkawasaki
Aug 25, 2011Aspirant
Help with routing
I just bought a GSM7328Sv2 as a pilot. The plan is to replace our 3Com 7757 modular cores with stacks of GSM's at all our locations. The 3Com cores are the default gateways for the sites. I'm too d...
captainkawasaki
Aug 29, 2011Aspirant
Did you ever know that you're my heroooo.....
You're everything I would like to be...
That was just what I needed. I added some more test vlans and got them routing, and just for fun slapped in the dhcp relay settings too. Everything works like a champ. Thanks for the directions--GD
