JulianSmith
Dec 15, 2021Aspirant
Help With VLAN Routing
Hello, I think I need to set up a couple of VLANs and pass traffic between them from different IP address ranges. Sorry if I am not doing a good job of describing what I need. This is not an area...
JulianSmith
Resolved, after talking to tech support, the switch I am using doesn't support inter VLAN routing.
schumaku
Dec 16, 2021Guru - Experienced User
Long before we could talk about inter-VLAN routing (leaving alone the intended S350 model does not support it) we need to talk about the intended "design". Consider each VLAN does make up an own (almost complete, independent) network, you can not wildly mix multiple VLANs configured as untagged ports for two and more VLANs.
There are certain special configs for so-called asymmetric VLANs, this is however a pure L2 technology permitting to isolate certain clients, say to isolate some L2 devices from being accessible from others. No routing involved ... and not really supported by Netgear due to complexity involved..
