Electrical
Apr 01, 2019Tutor
High hapibpdutxtask CPU usage
I'm thinking the cause of this is due to a large number of switches sharing the same broadcast domain with STP enabled. Is there a way to limit this activity without segmentation?
- Apr 04, 2019
Hi Electrical,
Welcome to our community! :)
Even if we disable the STP, the CPU usage will still be the same. It will be better if you could run an SNMP to your network to determine which OID provides a large process in your switch.
JohnCarloV
NETGEAR Community Team
JohnC_V
Apr 04, 2019NETGEAR Employee Retired
Hi Electrical,
JohnCarloV
