DelTorre
Sep 14, 2016Aspirant
how I can find the IP of a device connected to the switch GS724Tv4 ?
I have a switch Netgear GS724Tv4 and I need to know the IP address of a device at the g19 port. Is possible through the switch to see it? Thank you in advance. Antonio
- Sep 15, 2016
Hello DelTorre,
Welcome to the community!
Unfortunately, the GS724Tv4 does not have an IP address table. I don't see a way on how you can see it through the switch.
Thanks,
JohnRo
Sep 15, 2016NETGEAR Employee Retired
Hello DelTorre,
Thanks,
DelTorre
Sep 15, 2016Aspirant
Thank you so much.
I'll find another way :(
Antonio
- JohnRoSep 16, 2016NETGEAR Employee Retired
Hi DelTorre,
You can probably get the IP of each device on your router's IP address table, but it will not tell you which port it's plugged into on the switch. I think arp commands will work.
Thanks,
- JohnRoSep 19, 2016NETGEAR Employee Retired
Hi DelTorre,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
