DelTorre
Sep 14, 2016Aspirant
how I can find the IP of a device connected to the switch GS724Tv4 ?
I have a switch Netgear GS724Tv4 and I need to know the IP address of a device at the g19 port. Is possible through the switch to see it? Thank you in advance. Antonio
- Sep 15, 2016
Hello DelTorre,
Welcome to the community!
Unfortunately, the GS724Tv4 does not have an IP address table. I don't see a way on how you can see it through the switch.
Thanks,
DelTorre
Sep 15, 2016Aspirant
Thank you so much.
I'll find another way :(
Antonio
JohnRo
Sep 16, 2016NETGEAR Employee Retired
Hi DelTorre,
You can probably get the IP of each device on your router's IP address table, but it will not tell you which port it's plugged into on the switch. I think arp commands will work.
Thanks,
