parkck
Jan 18, 2020Aspirant
How to make network failover or redundancy?
HI -------- Line 1 ----------- Rounter ----| | ---- Network swich ----- PC -------- Line 2 ----------- I need to make ...
kevin_hong
Jan 19, 2020Apprentice
Hi parkck ,
Welcome to community,
There is two plans for you.
Plan A : Lyaer 3 plans: (Need you switch to support routing feature)
You can configure static or dynamic routing to achieve network redundancy and load sharing through routing priority configuration and routing strategy on both links
Plan B: Lyaer 2: (Need you Router to have LAN port and support STP feature)
Connect the two lines directly to the router's LAN port,Through the STP protocol, loop detection can be carried out and one link can be interrupted during operation to realize redundancy of two links
If you can provide netgear switch model and router model, I can offer more Suggestions
Thank you
parkck
Jan 19, 2020Aspirant
Thank you for reply this.
This is Local network (Class C) 2 strusture communications each others not such as 2 internet connections.
How about loop network/protocol? Do i need CISCO?
Thanks.
