parkck
Jan 18, 2020Aspirant
How to make network failover or redundancy?
HI -------- Line 1 ----------- Rounter ----| | ---- Network swich ----- PC -------- Line 2 ----------- I need to make ...
parkck
Jan 19, 2020Aspirant
Thank you for reply this.
This is Local network (Class C) 2 strusture communications each others not such as 2 internet connections.
How about loop network/protocol? Do i need CISCO?
Thanks.
kevin_hong
Jan 19, 2020Apprentice
Hi parkck ,
Plan C:
If there was only one Internet WAN port in your Router, i think you do not need two links from switch to router.
For example(Simple network):
Internet --------- Wan port-------Router-----192.168.1.0-----Swtich=========192.168.1.0 / 192.168.2.0
Key point:
Can you provide the detailed model of the router? It affect what scheme should be used if you really need to connect two links.
BTW:
For Layer 3 plan you can choose netgear switch that support routing, such as Smart switch(F4 GS728TPP) or Manage Switch M4300...etc
For Layer 2 pan you can choose netgear switch that support STP, such as Smart switch F4 or S350...etc
- jec956613Jan 24, 2020Tutor
There's also a third option: if your router supports LAG and your switches support stacking, you can run one line from each stack member to the LAG on the router, then one line from each stack member you wish to have highly available on the other side. Failover is usually fastest with this method and you aggregate more bandwidth, with the downside being that scheduled maintennace takes down the entire switch stack at once.
- parkckJan 26, 2020Aspirant
Thank you for reply
I'm still not sure
This is my model
Frontier DSL MODEL & Router Port #3 Line 1 - Wireless AP 1 - Bridge 1 - Managed Switch 1 Port #23
Frontier DSL MODEL & Router Port #4 Line 2 - Wireless AP 2 - Bridge 2 - Managed Switch 2 Port #24
Switch Port #23, #24 configure to LAG.
Is this working?
