oheli1
May 26, 2021Aspirant
How to Update POE-firmware on M5300-POE
Hello community, my stack consists of 7 devices mixed with M5300 and GSM7352Sv2. I noticed that two of the three M5300-POE have an older POE-firmware (1.4.0.3 instead of 1.7.03). I couldn't fin...
JohnC_V
May 28, 2021NETGEAR Employee Retired
You can manually update the firmware of the switch by copying the firmware from the master stack. You just need to identify the stack ID of the switch in order for you to assign it.
You may check this article.
John
NETGEAR Community Team
- oheli1May 31, 2021Aspirant
Hello John
I've already tried that before with no succees.
But on your word I'll tried it again and also restarted the switch
-> but it failed again.
POE-firmware still on version 1.4.0.3
As I mentioned: The main-firmware of all stacks currently is the same: 10.0.0.53
-> only POE-firmware differs ...Any other idea?
- JohnC_VJun 01, 2021NETGEAR Employee Retired
If that is the case then we may need to remove the switch from the stack and manually update its firmware in order for it to be running on the same versions as the others.
You may also need to reboot all the switches on a stack once you reconnect those switches so that it will re-elect its master.
John
