MKBKC's avatar
MKBKC
Can I create VLANS at my current firmware version on my MODEL M5300-28G-POE+
I am having issues:
1) Creating a VLAN on management switch 1 (Stack of 8)
2) Assigning that VLAN to another switch in the stack (Switch 5, Ports 1,3,5,7,9,& 11)
Basically my plan is to create the VLAN at my firewall, (Successfully done & tested) then pass it to a Port on my management switch 1, then get it over to another switch (#5) in the stack on a couple of ports (1,3,5,7,9, and 11) there.
I'm wondering if because I'm at the following firmware level (v10.0.0.44) wherby the current firmware level is 11.0.0.31 that is inhibing my creating VLANS.
Thank you
  • MKBKC,
    If ever you are referring about creating VLANs on the M5300-28G-POE+ switch, kindly access and read the article below as your reference guide:
    How to configure a VLAN on a NETGEAR managed switch
    About upgrading the firmware in a ladderized manner, kindly do it as I have mentioned on my previous response.  You can download the firmware version for the  M5300-28G-POE+ switch here.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi MKBKC,
    You should be able to create VLANs even if the firmware of your M5300-28G-POE+ switch is on firmware v10.0.0.44.  However, it would be best if your M5300-28G-POE+ switch is on the latest firmware version.
    If ever you decide to upgrade the firmware, I recommend that you do it in a ladderized manner.  First, upgrade the firmware from 10.0.0.44 to v10.0.0.53.  Then, upgrade from v10.0.0.53 to v11.0.0.10 and so on until you reach the latest firmware v11.0.0.31.  Be reminded to perform a factory reset after upgrading the firmware to the latest version then reconfigure it from scratch in order to start clean using the latest firmware version.
    DaneA
    • DaneA's avatar
      DaneA
      MKBKC,
      I just want to follow-up on this.  We’d greatly appreciate your feedback.
      DaneA
    • MKBKC's avatar
      MKBKC
      Just to verify I am doing this correctly, would you be kind enough to outline my footsteps for doing this.
      Thank you
    • DaneA's avatar
      DaneA
      MKBKC,
      DaneA
