erasto
Sep 30, 2023Aspirant
I can not be able to create DHCP on M4300-52G switch.
Can not be able to create DHCP pool on the switch. After saving, switch freeze, and can not allow me to anything, until reboot and login again.
erasto
Hello Team,
On this switch (M4300-52G), switch freeze, and I can not do anything there after click apply, on DHCP configurations. I need to create DHCP pools for different VLAN's, from this switch. I upgraded to the last firmware, but still the same problem.
michaelkenward
Sep 30, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Discuss Ethernet Switches Plus and Pro Managed
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
