erasto
Sep 30, 2023Aspirant
I can not be able to create DHCP on M4300-52G switch.
Can not be able to create DHCP pool on the switch. After saving, switch freeze, and can not allow me to anything, until reboot and login again.
michaelkenward
Sep 30, 2023Guru - Experienced User
Duplicated here:
I can not be able to create and configure DHCP ser... - NETGEAR Communities
schumaku
Oct 01, 2023Guru - Experienced User
michaelkenward wrote:
Duplicated here:
M4300 does definitively indicate a Managed Switch, these posts are in the appropriate community section already.
Considering the many features (Web UIs, CLI, ...), options, and variables, and in absence of a crystal ball, some more insight what was configured, ... would be more than great. Screenshots could help to clarify, also indicate the firmware version in use.
FMI: M4300 Intelligent Edge Series Fully Managed Stackable Switches, M4300 Series Switches, M4300-96X Modular Switch, User Manual, Software Version or Release 12.0.15 p.97 ff. Configure DHCP Server Settings
