Spellboundvfx's avatar
Jul 11, 2023
I need help on my l3 configuration.
Hi,
We have recently acquired an XSM4396KO-M4300-96X L3 switch and have successfully configured six VLANs within the switch. However, we are currently experiencing difficulties in establishing a connection between the switch and our firewall via an IPsec VPN.
Considering the urgency of this matter, we kindly request your expertise in remotely accessing our L3 switch configuration in order to determine and rectify the issue as soon as possible.
Please let us know when you would be available to assist us, and we will provide you with the necessary details to establish a remote connection.
Thank you for your prompt attention to this matter. We greatly appreciate your support in resolving this network connectivity issue
Thanks,
Anandan N
  • michaelkenward's avatar
    michaelkenward
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Discuss Ethernet Switches Plus and Pro Managed
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • MikeD1234's avatar
    MikeD1234
    NETGEAR Expert
    Hi Spellboundvfx,
    It's probably best that you speak to the support team, and/or raise a case through the support channels, to discuss discuss your request.
    But, from reading your post, normally, there isn't a VPN option available on an L3 switch. It would have to be Firewall -> Switch -> Users.
    And, if accessing remotely, connect to Firewall (VPN IPsec etc.) that then allows access to internal network.
    Could you shed some light on the configuration?
    Mike
ProSupport for Business
