pielab
Jan 14, 2022Aspirant
jgs524ev2 firmware upgrade
I have an old JGS524v2 that I would like to upgrade the firmware for. I got the ProSafe Plus Switch Utility installed on a laptop and it has a wired connection to the switch. I downloaded the last ...
- Jan 17, 2022
Hi pielab!
Were you able to access the admin page of the switch by typing its IP address?
If so, you can upgrade the firmware that way by going to System > Maintenance > Firmware Update.
But if there's no IP address showing in Utility or the NETGEAR Switch Discovery Tool (which can be downloaded here), please do the following:
Disconnect the switch from the existing network.
Press the Factory Defaults button of the switch for about 2-3 seconds.
Connect a computer directly to any Ethernet port of the switch.
Set a static IP address on the computer that is within the network 192.168.0.0/24 (like 192.168.0.100)
Open command prompt and try pinging the default IP address of the switch which is 192.168.0.239.
Check if you're able to access the admin page of the switch by typing its default IP address.
Please let us know if you're still encountering any issues.
Regards,JeraldM
NETGEAR Community Team
JeraldM
Jan 17, 2022NETGEAR Employee Retired
Hi pielab!
JeraldM
pielab
Jan 18, 2022Aspirant
Thanks for this. I don't know why I didn't try to connect via the browser. Dumb mistake. Can I ask another question? For this switch, I see it only supports Static LAG. How would I setup a Microsoft Team using two ports? I see from the NetGear doc how to do it on the switch side. System -> LAG -> LAG Membership, select ports. Then, System -> LAG -> LAG Configuration, select the ID of the LAG which I just setup and set the Admin Mode to Enable. But what are the settings on the Microsoft side? Would the Teaming mode be Static Teaming and the Load balancing mode be Dynamic (or Address hash)? Thanks!
- JeraldMJan 18, 2022NETGEAR Employee Retired
Hi pielab!
That is right. Given that the switch only supports static LAG, the teaming mode should be Static Teaming and its load balancing mode is either address hash or dynamic.
JeraldM
- pielabJan 18, 2022Aspirant
Thank you so much! You have been very helpful. Much appreciated!
