Digichip
Jan 03, 2018Aspirant
JGS524Ev2 Password reset assistance
I have read the password reset part on this unit, but I just purchased this unit, 'Brand New' in the box from a local auction house. None of the packages were opened in the box, but something must be...
- Jan 07, 2018
I just want to follow-up on this. We’d greatly appreciate your feedback.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
XavierLL
Jan 03, 2018NETGEAR Employee Retired
Hi Digiship
Welcome to our community!
About your issue accessing to the switch I would recommend to use the Insight App to discover it ( see instructions attached) . If this doesn´t work it´s likely that the switch is on his default IP address 192.168.0.239
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
- DigichipJan 11, 2018Aspirant
I have found the answer from the posts here and greatly appreciate all the responses. It did go back to the default address. Problem solved! Thank you all.
