Digichip
Jan 03, 2018Aspirant
JGS524Ev2 Password reset assistance
I have read the password reset part on this unit, but I just purchased this unit, 'Brand New' in the box from a local auction house. None of the packages were opened in the box, but something must be...
- Jan 07, 2018
I just want to follow-up on this. We’d greatly appreciate your feedback.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Jan 04, 2018NETGEAR Employee Retired
In addition to what XavierLL has mentioned, you may want to try the steps below:
1. Disconnect the JGS524Ev2 switch from your existing network.
2. Connect a PC any LAN port of your JGS524Ev2 switch.
3. Set a static IP address of 192.168.0.210 on your PC.
4. Open a browser like Google Chrome or Firefox then at the address bar of it, type 192.168.0.239 then press Enter. Login to the user interface of switch. Enter "admin" as the username and "password" as the password.
Note: The default IP address of JGS524Ev2 switch is 192.168.0.239.
DaneA
