Pedja21
Oct 03, 2016Aspirant
LAG with two PTP wireless links on Netgear 5300-28G3
Help for LAG with two PTP wireless Cambium links ! Juniper Extreme is solved on this link http://community.cambiumnetworks.com/bstrc49894/attachments/bstrc49894/kb_ptp_configuration_examples/30/1/P...
DaneA
Oct 04, 2016NETGEAR Employee Retired
Hi Pedja21,
Welcome to the community! :)
The configuration may or may not work with the M5300-28G3 switches. I think this kind of network setup has not been tested yet. However, since you have an existing online case with NETGEAR Support, it would be best to escalate your concern as feature request to the engineering team so that it would be supported or be compatible to work with the M5300-28G3 switches.
DaneA
NETGEAR Community Team
