arodriguez02
Mar 19, 2018Aspirant
Letter of Volatility Request for M4100-50G
Hello, I would like to request a Letter of Volatility for M4100-50G. Attaching a sample LOV for the information company is requesting. Let me know if you have any questions. Thank you!
JohnC_V
Mar 22, 2018NETGEAR Employee Retired
Hi arodriguez02,
Welcome to our community! :)
Here is the letter of volatility for M4100-50G. No password needed and the link will expire after 48 hr period.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- arodriguez02Mar 23, 2018Aspirant
Thank you for the response, but wonering why the actual document has a different model number than what was requested? Requested M4100-50G but the PDF says GSM7248v2? Need the letter of voltatilty to specifically say M4100-50G. Thanks.
- JohnC_VMar 23, 2018NETGEAR Employee Retired
M4100-50G is the product number and the GSM7248 is the ordering number. Please check our website for more information.
Would it be possible to have the LOV specifically say the model number instead of the ordering number? Only asking because customer is very picky about his. Apologize for inconvenience.
