dmcdaniel
Mar 06, 2019Aspirant
Requesting letter of volatility, GS105E-100NAS
Can I obtain a letter of volatility for a Netgear ProSafe 5-port Gigabit Ethernet Switch, GS105E-100NAS? Thank you
thanks again John. You've been a great help!
-Denis
- JohnCM_SNETGEAR Employee Retired
Hi dmcdaniel,
Here is the letter of volatility for the GS105Ev1. The link will expire after 48 hours. There is no password needed.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- dmcdanielAspirant
I am not able to open the link. It's giving me a login prompt, and it rejects my user/password (you said I don't need a password?)
Hi dmcdaniel,
I have re-uploaded the LoV. Please try it again.
Regards,- dmcdanielAspirant
Thank you John, I have it now. May I ask for a clarification, though? It shows 2Mbytes of flash memory and indicates that this is user modifiable. Process to Clear is "Use flash programmer," and nothing more. Is it possible to get more specific instructions than this?
