dmcdaniel
Mar 06, 2019Aspirant
Requesting letter of volatility, GS105E-100NAS
Can I obtain a letter of volatility for a Netgear ProSafe 5-port Gigabit Ethernet Switch, GS105E-100NAS? Thank you
- Apr 02, 2019
thanks again John. You've been a great help!
-Denis
JohnCM_S
Mar 06, 2019NETGEAR Employee Retired
Hi dmcdaniel,
I have re-uploaded the LoV. Please try it again.
dmcdaniel
Thank you John, I have it now. May I ask for a clarification, though? It shows 2Mbytes of flash memory and indicates that this is user modifiable. Process to Clear is "Use flash programmer," and nothing more. Is it possible to get more specific instructions than this?
- schumakuMar 06, 2019Guru - Experienced User
Look also here - https://community.netgear.com/t5/Unmanaged-Switches/Flash-programming-procedure/m-p/1712402 - this is a very strange process suggestion as part as a LoV. When you would go and erase the Flash, the switch would no longer boot, no longer be configured, no longer knowing it's a Netgear product, ...
The LoV should cover areas where potentially proprietary/private information like passwords, logs, network information, could reside which has to be erased before selling or giving a way a product. Can JohnCM_S please pick up and ensure engineering is adjusting this information accordingly on all (or at least many) similar Smart Managed Plus and Smart Managed Pro switch models.
