Test_JoeB
Oct 14, 2018Aspirant
Certificate of Volatility Request
Hi,
Please send me a copy of the Certificate of Volatility for JG524v2 ProSAFE 24-port Gigabit Unmanaged Switch.
Joe
Hi Test_JoeB,
Welcome to our community!
Here is the certificate of volatility for JGS524v2. No password needed and the link will expire after 48 hour period.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- JohnC_VNETGEAR Employee Retired
Hi Test_JoeB,
- Test_JoeBAspirant
Hi John,
I have downloaded the certificate. Thanks for the quick response on the matter.
Joe
