dmcdaniel
Mar 06, 2019Aspirant
Requesting letter of volatility, GS105E-100NAS
Can I obtain a letter of volatility for a Netgear ProSafe 5-port Gigabit Ethernet Switch, GS105E-100NAS? Thank you
- Apr 02, 2019
thanks again John. You've been a great help!
-Denis
JohnCM_S
Mar 06, 2019NETGEAR Employee Retired
Hi dmcdaniel,
Here is the letter of volatility for the GS105Ev1. The link will expire after 48 hours. There is no password needed.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnCM_S
Hi dmcdaniel,
I have re-uploaded the LoV. Please try it again.
- dmcdanielMar 06, 2019Aspirant
Thank you John, I have it now. May I ask for a clarification, though? It shows 2Mbytes of flash memory and indicates that this is user modifiable. Process to Clear is "Use flash programmer," and nothing more. Is it possible to get more specific instructions than this?
- schumakuMar 06, 2019Guru - Experienced User
Look also here - https://community.netgear.com/t5/Unmanaged-Switches/Flash-programming-procedure/m-p/1712402 - this is a very strange process suggestion as part as a LoV. When you would go and erase the Flash, the switch would no longer boot, no longer be configured, no longer knowing it's a Netgear product, ...
The LoV should cover areas where potentially proprietary/private information like passwords, logs, network information, could reside which has to be erased before selling or giving a way a product. Can JohnCM_S please pick up and ensure engineering is adjusting this information accordingly on all (or at least many) similar Smart Managed Plus and Smart Managed Pro switch models.
- dmcdanielMar 25, 2019Aspirant
Hi John, sorry to trouble you again, somehow I lost the document. Could you possibly repost the link for me? Thanks!
Denis
- JohnC_VMar 27, 2019NETGEAR Employee Retired
- dmcdanielMar 28, 2019Aspirant
Thanks again John (I saved it this time!).
Now I have another question. I discovered that the instrument that I have is "v2" not "v1". Someone else I work with had a letter of volatility for the v2, and there is a difference that I wanted to ask about. The letter for the v2 shows the same entry for 2Mbytes Flash memory that the v1 letter has, but shows this as being non-user modifiabe, whereas the v1 letter says it is user-modifiable. This is a very important difference for my purposes, and I was wondering if I could get a confirmation that the respective letters are correct? Thanks
