tensi0n519
Oct 01, 2019Tutor
Link Aggregation between GSM7224R and M4100-50G-POE+ setup help
I have two switches, M4100-50G-POE+ and GSM7224R . I am trying to set up link aggregation between both of them using the last 4 ethernet ports on each. I'm not exactly sure as to what needs to be set...
- Oct 02, 2019
Welcome to the community! :)
Let me share the article below and use it as your reference guide:
How to configure LAG between two NETGEAR managed switches?
If your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
tensi0n519
Oct 02, 2019Tutor
I was able to fix the issue. Turns out it was a firmware issue. Had to update the firmware on both switches and they work as they should now. Thanks again for your help.
DaneA
Oct 03, 2019NETGEAR Employee Retired
You're welcome! :) I'm glad that you were able to upgrade the firmware of both switches and got it working.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
