mbkitmgr3
Mar 11, 2018Aspirant
Link UP/Down events on select inactive ports M4100-24G-POE+
We recently included this device in our SNMP moitoring system Every few seconds ports report Link UP/Iink DOWN on ports not yet connected to any devices. The other oddity is that some report this mo...
mbkitmgr3
Mar 14, 2018Aspirant
Hi EricZ,
Thanks for your assistance with this task.
I was able to arrange an outage last night to update the firmware V10.2.0.26. From a check this morning the behaviour hasn't changed.
I also receive advice from the device when I try to obtain the Tech Support log that it "is either empty or not found". Is there something in the config of the switch that I have missed for the device to report this.
I have downloaded any log/scripts/configs etc that would succeed and will submit them via the method requested
Retired_Member
Mar 14, 2018Hi mbkitmgr3,
You can run CLI command as 'show tech-support' first on console port or telnet port, and try again.
Hope it helps!
- mbkitmgr3Mar 14, 2018Aspirant
HI EricZ
Thanks again.
I have emailed the techsupport file to the email address supplied
- Retired_MemberMar 14, 2018
Hi mbkitmgr3
Thanks for your immediately response, I got the tech-support file.
And there is port flapping for port 0/9 as below:
1 Mar 15 02:17:58 2018 Link Up: 0/9
2 Mar 15 02:17:54 2018 Link Down: 0/9
3 Mar 15 02:16:56 2018 Link Up: 0/9
4 Mar 15 02:16:52 2018 Link Down: 0/9
5 Mar 15 02:16:19 2018 Link Up: 0/9
6 Mar 15 02:16:16 2018 Link Down: 0/9
7 Mar 15 02:16:09 2018 Link Up: 0/9
8 Mar 15 02:16:07 2018 Link Down: 0/9As the port not connect any device, maybe it's hardware issue.
Two suggestion for you:
1. Do factory default for the switch, and see if it still happen or not?
2. It would be best that you open an online case with Netgear Support for further assistance. If it's hardware issue, support will replace new one to you.
Hope it helps!
- mbkitmgr3Mar 30, 2018Aspirant
HI Eric,
Lodged a support request, had a remote support session with a Tech Support rep from NetGear. He didnt agree that there was an issue. We have elected to retire the device as a spare.
Thank you for your help
