mbkitmgr3
Mar 11, 2018Aspirant
Link UP/Down events on select inactive ports M4100-24G-POE+
We recently included this device in our SNMP moitoring system Every few seconds ports report Link UP/Iink DOWN on ports not yet connected to any devices. The other oddity is that some report this mo...
Retired_Member
Mar 14, 2018Hi mbkitmgr3
Thanks for your immediately response, I got the tech-support file.
And there is port flapping for port 0/9 as below:
1 Mar 15 02:17:58 2018 Link Up: 0/9
2 Mar 15 02:17:54 2018 Link Down: 0/9
3 Mar 15 02:16:56 2018 Link Up: 0/9
4 Mar 15 02:16:52 2018 Link Down: 0/9
5 Mar 15 02:16:19 2018 Link Up: 0/9
6 Mar 15 02:16:16 2018 Link Down: 0/9
7 Mar 15 02:16:09 2018 Link Up: 0/9
8 Mar 15 02:16:07 2018 Link Down: 0/9
As the port not connect any device, maybe it's hardware issue.
Two suggestion for you:
1. Do factory default for the switch, and see if it still happen or not?
2. It would be best that you open an online case with Netgear Support for further assistance. If it's hardware issue, support will replace new one to you.
Hope it helps!
mbkitmgr3
Mar 30, 2018Aspirant
HI Eric,
Lodged a support request, had a remote support session with a Tech Support rep from NetGear. He didnt agree that there was an issue. We have elected to retire the device as a spare.
Thank you for your help
