JNolan
Jul 15, 2016Aspirant
"located on ip network" is not getting router as gateway - dropping connection
I have a new Arris modem from Brighthouse cable. Also have JGS524Ev2 and GS108E. Both of the netgear devices are on the newest firmware and set to DHCP. Oddest thing is when looking at them through C...
JohnRo
Jul 15, 2016NETGEAR Employee Retired
Hello JNolan,
Welcome to the community!
I have some questions before I can give you an advice. How do have the devices connected? Do you have a diagram of your network?
Looking forward to your response.
Thanks,
JNolan
Jul 16, 2016Aspirant
Thanks for the reply! Seems the issue I am having after some more troubleshooting is when I power off my PC with the prosafe software, it kills my entire network.
Here is the order of network.
Modem --> Path 1: Switch (Netgear with issue) Right now 2 devices attached. This PC and Smart TV.
Modem --> Path 2: Switch (unmanaged) to other various devices around the house and 1 PC.
Everything is set to DHCP and then I reserve IP and usual port forward. No repeats on any devices or ports. Have reset modem/router. Seems whenever I shut this PC down, network goes down with it. Never had this issue before this new Netgear device, which is also a replacement.
If I use my old Dlink DGS-1224T I have zero issues. Was buying these to kind of replace some of the older hardware. Couple months old now so I can't get my money back.
Any thoughts?
Also, below is my ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Z400i7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet 3:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet
Physical Address. . . . . . . . . : 00-10-18-11-C1-93
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : ::e986:552c:c8d4:d61f(Preferred)
Temporary IPv6 Address. . . . . . : ::243a:79f2:4b77:5d5e(Preferred)
Link-local IPv6 Address . . . . . : fe80::e986:552c:c8d4:d61f%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, 16 July, 2016 16:23:41
Lease Expires . . . . . . . . . . : Saturday, 16 July, 2016 17:23:42
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 184553496
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1B-7E-9D-78-3C-D9-2B-73-CA-DB
DNS Servers . . . . . . . . . . . : 75.114.81.1
75.114.81.2
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 5:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:3c3f:2263:3f57:fffc(Preferred)
Link-local IPv6 Address . . . . . : fe80::3c3f:2263:3f57:fffc%13(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 301989888
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{88CC3F81-3559-496A-9DCC-58D3278CA1B7}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
- JohnRoJul 18, 2016NETGEAR Employee Retired
Hi JNolan,
I don't see a router on your network order. I believe that you are aware that the JGS524Ev2 and GS108E are not DHCP servers. Usually, an arris modem only gives you a single IP address. So this brings me to another question, which device gives out the IP addresses? Where is your DHCP server?
Thanks,
- JNolanJul 19, 2016Aspirant
Morning,
The Arris is a modem / router and is set up as such. Like I said, all other devices work as designed. Only issue is when I use the NetGear routers. It also seems to be more frequent after the last firmware update as it did not occur at all with the GS108e until the firmware update was done.
Right now all is running perfectly. Last test I tried was Router to Netgear to PC I am on. Also had my smart TV on watching Netflix. All runs perfectly until I turn my PC off. Once I do that, the TV loses internet. Thought it might have been a setting on the nic. Uninstalled the NIC and put a new PCI NIC in for testing with the same issue. Also put a laptop in place of the PC and same issue.
Also had assigned IP's to every device by MAC address on the Arris. All IP's were noted and correct. Then ran the same tests with everything getting IP DHCP and same issue. This is definitely something I have not come across before.
Thanks for the help!!
- JohnRoJul 20, 2016NETGEAR Employee Retired
Hi JNolan,
Good to know that you have it working. The PC issue is kind of weird , I have not seen such behavior. As long as the switches are behind the router or the DHCP server, IP addressing should be good.
Let us know if you have more questions, otherwise please mark the post that resolved the issue as "Mark as solution".
Thanks,
