SteveR85
Jun 25, 2018Follower
Looking for best configuration of XS708T 8 Port ProSAFE 10GbE X Series Switch to connect SAN to Host
I have a SAN with 8 ports that is split using 2 switches (only 1GB) to 2 hosts
I want to know the best config for two XS708T 8 Port ProSAFE 10GbE X Series Switchs to allow the best comunication between the SAN and the hosts
The swithces are not connected to the outside world and will be only used for the interconnection of the SAN to the host
thanks in advance
1 Reply
- JohnC_VNETGEAR Employee Retired
Hi SteveR85,
Welcome to our community! :)
Setting up the switch will always depend on how you want your network to be setup and how many cables are you going to use in order for you to have a great speed. This article may help you understand the way you can setup your switch with SAN.
What are link aggregation and LACP and how can I use them in my network?
