b33k's avatar
b33k
Tutor
Aug 19, 2021
Looking for help for LACP/Vlan configuration for RBR750/CM2050V/GS110EMX
I have the following equipment all Netgear GS110EMX switch, Orbi RBR750, CM2050v Modem.  What I have been trying to do is use the GS110EMX switch to create a seperate VLAN2 (Port based) with just t...
  • schumaku's avatar
    Aug 20, 2021
    No idea if the port-based VLAN and the LACP LAG is really compatible.
    Please try the real 802.1q-based VLAN config, create a VLAN xxxx, create the LACP-LAG, remove the default VLAN 1 from the port and the LAG, make the LACP-LAG and the multi-gig-port for the Modem link [U]ntagged, and last but not least don't forget to put up the VLAN xxxx as a PIVD for the LACP-LAG and the multi-gig-port.for the Modem link.
    Beyond I'm afraid, no practical current WAN-port LAG-experience on the Orbi systems on my side.
ProSupport for Business
