JohnO2016
Nov 16, 2016Aspirant
M1400 Time Config
So I'm configuring the SNTP settings, and get to the Offset and Zone. Not being sure how these fields are to be filled, I look at Help. Offset - This field is used to configure Recurring offset. ...
JohnO2016
Nov 17, 2016Aspirant
Thanks for the info, we're getting closer. :-)
So for Zone, is it looking for EDT or CST or something like that? Or something like UCT-5?
Same for Offset, my switch doesn't indicate hours or minutes. Using "1" could give very different results depending what the switch is expecting. Maybe it's "1h" or "60m"?? (And really....there are two small places on the planet that do anything other than one hour...)
Thanks again!
LaurentMa
Nov 17, 2016NETGEAR Expert
For Zone, this is text box for your convenience only. Name your time zone the way you like, this is for your own use.
Offset hours / minutes are the important parameters, where you specify how far you are from UTC.
Now I realize you named this post M1400, and I have read it as M4100 instead.
If you don't see hours and minutes in the Web interface, the same way we show them in M4100 Web GUI User Manual starting page 37: << View or Set the System Time >> and more specifically for the Zone and the Offset on page 40, then we may be confused. Which switch do you have?
Can you check? Please kindly go to System-> Management-> System Information as described on page 23 of our M4100 Web GUI User Manual
Please copy and paste here full text on the right side of Product name.
- JohnO2016Nov 17, 2016Aspirant
Whoops, I'm sorry, I have the M4100-D12. My apologies. :smileyhappy:
So, I interpreted Zone as time zone, which in the US is EDT, CDT, MDT, or PDT. etc.
And, we are UTC-5 here, so -5 works in that field.
I respectfully suggest sending this one to the people who write the Help screens and manuals. Your explanation is good. :smileyvery-happy:
Thanks for your assistance, I understand it now.
- LaurentMaNov 17, 2016NETGEAR Expert
We are glad you finally set up your time correctly on NETGEAR M4100 Series managed switch.
Thank you for letting us know. Yes, I will make sure we can explain parameters better in Help screens as you suggest.
I believe our manuals are correct (they are related to latest firmware branch, so 10.0.2.x currently).
If your M4100-D12G (GSM5212) shows different settings in web interface, it must mean you are running previous software.
No obligation, but feel free to consult M4100-D12G support page, and download latest 10.0.2.20 in Firmware and Software download section.
After upgrading, you should see same presentation as in our latest user manual.
