MCEComputers
Nov 27, 2022Apprentice
M4100-24G-POE+ switch has no POE
I have M4100-24G-POE+ switch that is working fine except for POE. I found this post with a similar issue and tried downgrading the firmware to 10.0.2.26 but Poe Version on the System Management p...
- Dec 05, 2022
Thanks for that information. The switch was purchased used so it would not be covered by the warranty.
I finally had an opportunity to open the case a take a look inside. I found that the original fans had been replaced and the POE power board had apparently been unplugged for easier access to the fan connectors. The plug for the POE section had not been plugged in all the way. I pulled the plug and pushed it back in properly. When I started the switch back up all of the POE configuration information was back and the ports were supplying power as expected. Everything has been working fine since, so that seems to have been the cause.
DaneA
Nov 28, 2022NETGEAR Employee Retired
Let us try to perform a factory reset on your M4100-24G-POE+ then observe if the same problem will occur.
DaneA
NETGEAR Community Team
MCEComputers
Nov 30, 2022Apprentice
I have factory reset the switch several times while trying to troubleshoot the problem.
