ShooterDS
May 12, 2020Follower
M4100-26-POE IPV6 DHCP Relay
Hello, We use M4100's on our QA network. We are testing a device that uses DHCP V6. We need to test the device on the 'other side' of a DHCPV6 relay to validate proper behavior. I've looked...
JohnC_V
May 12, 2020NETGEAR Employee Retired
Welcome to our community! :)
Only our M4300 series supports the DHCPv6 Relay and you may also check the CLI commands on page 507 of the Software Administration Guide.
I hope it helps!
John
NETGEAR Community Team
