DG77
May 08, 2019Aspirant
M4100 26 POE with no gigabit
Hi all,
I've been trying to diagnose an issue with my M4100 not being able to get any gigabit speed (as reported by both ethtool and the netgear admin console). In total I've tried the followin...
DG77
May 09, 2019Aspirant
Here is the information I've added to the support ticket. It includes a bit more info:
The problem I am having is that none of the ports are auto negotiating to 1000mbps. This did use to work.
The things I've tried so far are:
1. Replaced all patch cables with new Cat6 cables.
2. Upgrade firmware to the latest (shown in "device status" as 10.0.2.30)
3. Factory reset using the menu option: Maintenance > Reset > Factory Default
4. Tested a server connected to the switch with ethtool. The output shows the following "Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full".
5. Connected a gigabit capable PC directly to the switch using the new Cat6 cable. Speed is still showing as 100mbps.
6. Connected the same PC directly to an un-managed Netgear switch. PC and lights on switch show connection at 1000mbps.
7. Replaced the M4100 switch with the un-managed switch. This showed all gigabit capable devices as connecting at the full 1000mbps as expected.
8. I also tried connecting the M4100 and un-managed switch together using the Cat6. Both sides show only 100mps connections.
All tests were done before and after a factory reset.
After the factory reset all ports did not have anything plugged in apart from the PC I was using to configure the switch.
JohnC_V
May 09, 2019NETGEAR Employee Retired
Hi DG77,
Welcome to our community! :)
It seems that you pretty isolated the issue and this is working before. Then, this is already for RMA. I checked your case and it seems that it is now ongoing.
JohnCarloV
NETGEAR Community Team
