onyangodt's avatar
onyangodt
M4100 12GF Firmware
Greetings,
I have recently upgraded the firmware on my M4100 12GF (GSM7212F Layer 2+ ) switch. The switch will not save any configurations and everytime I reboot the switch it does not save the configuration. Every time I try and save the configuration using CLI, it says Config file 'startup-config' created successfully,Configuration Not Saved! When I log back into the switch none of the passwords or configurations are saved and the Switch defaults to factory settings. From what I can tell this may be due to there not being enough memory on the switch but I'm not too sure. Is there a way to downgrade the firmware or is there a way to free up the memory on the switch to accommodate for configurations. Prior to doing the firmware upgrade, it would save the configurations and work just fine. Now nothing holds.
Any help would be appreciated.
  • Hi onyangodt,
    Very strange...
    Maybe the flash is broken on this M4100.
    Please check private message for maintenance commands.
    Thanks.
    • DanielZhang's avatar
      DanielZhang
      NETGEAR Expert
      Hi onyangodt,
      Welcome to NETGEAR community!:smileyhappy:
      It seems that this M4100-12GF don't have enough space on flash.
      I suggest you to clear the unused data on it.
      The data can't recover after following operation.
      So please think about it carefully before do following operation.
      1.   Clear the log on flash by CLI
      These log just used for NETGEAR support.
      No harm to M4100.
      Cleare crashlog
      Clear event and trap log.
      2.  Clear scripts on flash by CLI
      Input the script name which youo want to delete.
      Or input delete all to remove all scripts on flash.
      4. reload M4100 and try to save configuration again.
      May the solution help you.:smileyhappy:
      Thanks.
      • onyangodt's avatar
        onyangodt
        Greetings Daniel,
        It still refuses to save to configuration. I managed to downgrade to the firmware that was installed before I attempted the firmware upgrade. Im still getting the same problems. Prior to the firmware upgrade everything was saving and configurations were saving. Now after the firmware upgrade and downgrade it wont save. Ill use the EZconfig prompt to get the initial setup and it wont save those settings either. Then ill reboot the switch to see if they stuck and they don't. Please see the screenshots below.Screen Shot 2017-05-18 at 11.03.30 AM.png
ProSupport for Business
