onyangodt
May 17, 2017Aspirant
M4100 12GF Firmware
Greetings, I have recently upgraded the firmware on my M4100 12GF (GSM7212F Layer 2+ ) switch. The switch will not save any configurations and everytime I reboot the switch it does not save the ...
- May 18, 2017
Hi onyangodt,
Very strange...
Maybe the flash is broken on this M4100.
Please check private message for maintenance commands.
Thanks.
DanielZhang
May 18, 2017NETGEAR Expert
Hi onyangodt,
Welcome to NETGEAR community!:smileyhappy:
It seems that this M4100-12GF don't have enough space on flash.
I suggest you to clear the unused data on it.
The data can't recover after following operation.
So please think about it carefully before do following operation.
1. Clear the log on flash by CLI
These log just used for NETGEAR support.
No harm to M4100.
Cleare crashlog
Clear event and trap log.
2. Clear scripts on flash by CLI
Input the script name which youo want to delete.
Or input delete all to remove all scripts on flash.
3. Clear the persistent log on flash by GUI
4. reload M4100 and try to save configuration again.
May the solution help you.:smileyhappy:
Thanks.
onyangodt
May 18, 2017Aspirant
Greetings Daniel,
It still refuses to save to configuration. I managed to downgrade to the firmware that was installed before I attempted the firmware upgrade. Im still getting the same problems. Prior to the firmware upgrade everything was saving and configurations were saving. Now after the firmware upgrade and downgrade it wont save. Ill use the EZconfig prompt to get the initial setup and it wont save those settings either. Then ill reboot the switch to see if they stuck and they don't. Please see the screenshots below.
