ronaldpeeters
Feb 01, 2018Aspirant
M4100-50G-POE+(GSM7248P) auto reboot
Is it possible to auto reboot this switch every night? I need to reboot it every 1-2 weeks to keep working.
JohnC_V
Feb 02, 2018NETGEAR Employee Retired
Hi ronaldpeeters,
Welcome to our community!
GSM7248P doesn't have auto-reboot feature. May I know what seems to be the problem?
- ronaldpeetersFeb 03, 2018Aspirant
There are 8 access points (WAC720) connected via POE to this switch. Every 1-2 weeks my customer complains that his users cannot connect to internet with their smartphone. When I check the access points (are in ensemble config) they seem to be fine but a reboot of the switch (and via poe also the access points) makes the system working again.
- JohnC_VFeb 05, 2018NETGEAR Employee Retired
Maybe there is something going on inside the network that causes flood for the switch to stop working. May you be able to run syslogs so that we may know what seems to be causing that issue?
- NoufalJul 04, 2022AspirantI am facing same issue, i have 5 vlan and 5 vlan gatway are M4100 fiber switch, dhcp enebled every week need to restart the divece
