boe
Jun 09, 2023Luminary
M4300- multiple VLANs connected to GS510PP
Hello, I'd to connect port 48 of an m4300 to port 1 of a GS510tpp. I have 5 vlans. VLAN 10 is my default vlan for all wiring e.g. servers, switches etc. I can't seem to figure out how to ...
schumaku
Jun 09, 2023Guru - Experienced User
No matter what systems you fancy for trunking (Managed M4300, managed M4250, managed M4350, or Smart managed switches like a GS510PP, or a plus switch like e.g. a gs308E for example, make all VLANs on the port (or for sake the LAG is multiple links are required) [T]aged. Your homework is to figure out on how this was configured before.
The PVID has only relevance to define the VLAN you want incoming untagged frames to be assigned to on the switch. Should this be an untagged (access-port-like) defined as [U]ntagged, this will make the frames from that VLAN coming out on the port (or LAG) untagged.
Write down what you want exactly on the trunk, for example like VLAN 2, Tagged; VLAN 3 Tagged, .... VLAN 10 Untagged Access port, with PVID 10.
- boeJun 09, 2023Luminary
Thanks - Anyone know where to go to make it work and what settings to change? I'm starting from scratch so nothing has changed.
I'm happy to share picatures.
